- Jun 8, 2011
- 8
Hello pool vac guru here, once again I have a problem with my Polaris 380. When the Polaris is on the cleaner does it’s normal routine, but after the backup valve activates for the first time of the day, the cleaner stays where the back valve puts it. The sweep hose moves but the wheels do not turn. when I shut it off and turn it on minutes later it works fine then the same thing happens over and over again. Considering the fact that the cleaner is 15 years old, should I fix it or replace the whole thing!!! Thank you for reading this post.
Sincerely the Pool vac guru.
