- Jun 8, 2011
- 9
I recently got a new pool vac with a hose instead of the vacuum that came with it using the water hose. I'm having trouble though, i've gone through the directions several times and i'm not missing anything. Everything is hooked up where it should be, but what I do think my problem is, is filling the hose with water.
I connected the one end of the hose to the vacuum head and put it in the pull, then had the other end to the diverter to fill it up with water. It just won't fill completely. The hose is only 26 feet long, so I don't see how it could take 15mins+ to fill. It doesn't really make much sense to me because wouldn't the water that I'm putting in the hose just run out of the other end that's already in the pool?
I've checked and checked for holes in the hose and have found none. It will fill up some, just not all the way. Any tips on what to do?
