- May 30, 2011
- 6
First the normal...love the site and I have found a ton of good info..I searched but cannot find a specific answer to this question.
I have a two speed hayward pump with the switch on the back cover. I also have the Hayward Aquarite SWG plus that can control both speeds of the pump.
I currently have it wired just running the switch to control the two speeds, but as i add stuff to my SWG controller (low voltage lights etc) I want to change the wiring at the pump to take advantage of the controllers ability to switch the pump from low to high.
My question is "How do I do that?"
My controller basically shows four feeds coming from it when runing a two speed pump (from two different control relays in the system) but how do I "remove" the switch.
There is a white wire going from the switch to the motor, and a yellow and black wire going from the switch to the "junction" where the pump recieves it's feed from the panel/controller.
If you need pics let me know I can snap a couple today
