Nice pool! Is that a bench or a spa? I'm jealous...
Go to
http://poolcalculator.com Enter in your volume at the top. Then go to the bottom and set your goals to Trouble Free Pool.
Then enter the numbers you just posted into the "now" column.
Enter 80 into the CYA, and once you do that the pink area in the bottom (chlorine goals) will adjust for your CYA level. It'll give you a minimum, maximum and two shock values (normal and mustard).
In the first section at the top, change or verify that 6% bleach is listed as your chlorine source.
Since it's evening, you will want to enter into the "target" column the high value from the pink section. For CYA of 80, that is 11ppm. Enter 11 into the target column and tab or click out of the area and you'll see it calculate the amount of bleach to add.
Your CYA is a bit high, but for right now all you need to do it get chlorine into the pool. We'll help you lower the CYA later.
PH is also at the top of the ok range. It might be worthwhile to lower that to 7.4 with acid tonight as well.
Once you get some chlorine to stick around in the pool, you can go back to the store and try for a CC reading.
Now go calculate, add the chlorine slowly in front of a return and leave the pump running. As long as you don't have an algae bloom started, the max should get you through the night and tomorrow. That's ideal BTW... If you loose all that chlorine tonight something is definitely amiss.
Are you running completely blind with no way to test chlorine and ph right now at home?
