Our new pool has 3 SAVI color changing LED lights. You cycle through the different colors by turning the switch off then back on again. The first color in the sequence is white. One of the other colors later in the sequence is pink.
When all three lights should be on white: Two of the lights correctly glow white. The other light shows sort of half white half pink. When the lights are on the other colors all three correctly show the correct identical colors, including pink. All three are in sync on the same colors, it's just that for one of the three lights, on the white color setting only, there's some pink mixed in.
Has anyone seen this before? Any thoughts on what's causing it and how to fix it?
