Speaking of the deck, I will make sure its tight, and my concrete guy is also going to posthole it every 5-6' to be sure it has a good base.
I have read a lot about the wire, rebar, or just fiber. Now, I am subb'n all this stuff out (mainly using PB's referred people tho) but none the less, if I want rebar or wire, I will have to get the concrete guy to come out and form it and lay in the wire and float it (which he does do), then call the electrician back out to bond it. Then everyone leaves for a day or 2 to wait on an inspection before pouring the deck.
Also my elec. already ran a bonding wire around the pool and hit the ladder, diving board, handrail, and screwed it into the steel walls every so often, so I dont know how much trouble it would be for him to "redo" it. Or can you just a clamp of sorts and clamp the copper wire to the mesh every so often, if that can be done it would be easy.
I am just not sure how the parties involved will take to it, have to do this, leave, wait, come back, etc...Should I just feel OK with doing fiber and nothing else, or is it "whatever it takes, do the wire to" type of thing?
