Hooray, I received the TF-100 kit today and WOW, I love it! So easy to follow. The plaster was done on the 30th and equip. began running on the 6th to it's still new.
I took some readings and they are:
FC 1ppm - tho I suspect this is actually at 0
Ph - was 8 earlier but 1.5 hours after adding 2 qts. muriatic acid, it is now 7.2. Is this ok? Suspect this will continue to bounce due to fresh plaster
T/A 130 (?) This one always confuses me because it never turns red but a deep bright pink. So going by the pink, it was about 130
CH 210 - again, it was more of a purple-blue and I stopped adding at 21 drops
CYA - I saw the dot the whole time
2 chlorine pucks in 2 skimmers currently. I have 2 buckets of calcium chloride. PB added some on the 6th (so cool how it heats up!) but we have not added any since.
In 2 weeks we turn on the SWG system so in the meantime, any thoughts on what I should do? Thanks oodles!
