Hello, I am a new pool owner and noticed that my chlorine has been getting low (even after a shock). I checked the "pool frog" and noticed it was out of chlorine tabs. I did not have another "frog bac pac" so I thought I could put the empty pac back in and still run the filter. When I tried water started shooting out of the "pool frog" (while covered). I later realized that I did not turn the dial (on the frog) to the "replace pak" setting. When I get a full pak will this problem be gone or did I do some damage with my stupidity?
