Going to need more information than what you've provided. Pool type, filter type, salt water or no, chlorine type to sanitize, and a full set of test numbers. Pictures wouldn't hurt any either.
i have a sand filter and the poolis above ground 18 round i use 3 inch chlorine tablets i dont have the numbers with me im at work i put in pool shock 32oz algacide and cholrine
Some of the common algaecides will cause foaming. If that is the problem then you just have to wait it out, up to about a week before the foam goes away completely.
