Hello. I know the little lever under the skimmer bucket opens and closes the bottom drain. But should it be in the up or down position when under normal use? Thanks.
The lever is aligned with the plate so whichever way the lever is aligned shows you the position of the plate. If it's vertically 'up and down' the MD isn't pulling at all. You can adjust the 'flap' on top to allow more suction from the MD.
This response might not be 'crystal clear', but you can always ask follow up questions :-D
