:? This is the 2nd summer i have had my pool. I decided this past winter to treat the water and cover it for the winter..Things looked good until about february it started turning green...Due to some surgery i had in february i was'nt able to uncover the pool until april. I went to my local pool chemical supplier and they set me up with a 5 days plan i think it was to treat the algae and the water to get it ready for start up. It went from green and is now a cloudy light blue color and has been that way for 2 months now. The pool is clean and no debris in it and have all levels good by the testing of the water. I have clarified, lower the ph with muriatic acid, shocked you name it i have done it. This past weekend i used floc out directions to the tee..... No luck...Then we use poly brite tabs, then natural clarifier still no luck. Chemical rep said give it a coulple of days seems to think pump not big enough to circulate water properly but its what came with the pool when i brought it. So today its still cloudy....I never form day 1 of starting the pool last year ever had this problem...Needless to say if i ever get it clear i will never cover it again for the winter...For the money i have spent in chemicals so far i could have bought a new pool system....Please any advice would help....The chemical rep is still working on it.....
Fc 3.1
tc 3.6
cc 0.5
ph 6.8
hd 270
alk 84
ca 20
copper 0.6 last check but has been treated to lower should be lower now.....
Fc 3.1
tc 3.6
cc 0.5
ph 6.8
hd 270
alk 84
ca 20
