HI EVERYONE!!!
EUREKA!!! I HAVE STRUCK PAY DIRT!!!
I checked my chlorine levels last night and it was around 20ppm FC. I checked it again this morning and it was holding at 15ppm.
The water is crystal clear. Still have some settling of white stuff on the bottom (minimal) will vacuum to waste again. I also have some floating in the water. Should I use a flock to force it to the bottom and then vacuum to waste? I know that I have to leave the filter off for 24 hours and I did not know how that would effect my process. :? :?
I took the rest of my readings and they are as follows:
FC - 15ppm
CC - 1 ppm
ph - 7.2
TA - 110
CH - 110
CYA - Filled to top of the tube and could still see the black dot. I measured the water and the chemical exactly and waited 30-35 seconds and shook again before performing the test. Used all of the solution and the dot never went away. Mixture was clear all the way to the top. :? :?
Can anyone tell me what my next steps should be. I am so excited to have this just about finished. I am excited about closing it down before winter.
I usually dink around and don't shut it down 'til November and it is mighty cold trying to do it then.
I will actually get to close it down in shorts this time. Hooray! :-D
:sun:
Thank you all so much for the encouragement and help so far. I couldn't and probably would not have come this far. Once that sucker turned it's first shade of green I would have drained it so fast. Thanks for helping me hang in there. :bowdown: :bowdown:
Hope to hear from you soon.
Ptravis
