Spraying
Sunday PB sprayed pool knowing it was the day before trees to be cut down. The outline did not look right and the guy spraying it was having trouble laying it out. I told him before he sprayed and sales person new, that the next day, Monday three trees would be cut down. He asked if they could try and not mess up the lines and stakes he had put down. This was impossible as 6 workers worked tirelessly for 8 hours cutting down the trees. Stump grinder in use as well.
Tree cutting - stump issue
Trees cut, Foreman EDIT /spray guy tells me I only need to grind 2 of three stumps. I tell my grinder that PB will pull the last stump. PB's diggers could not or would not pull last stump so I had to pay stump guy again to come out, he has a minimum. This cost me an extra $100.00 as if he had done it when here originally it would have been a $75.00 stump. To come out again just for the one stump was $175.00
Immediate digging
Day after trees cut PB re-sprays outline, and immediately begin to dig. This gave us no time to really study the design. Not really very reasonable. We did think it was drawn wrong this caused serious concern and confusion.
Irrigation
Irrigation, the contract says and sales person told me that the irrigation system would be cut, and capped and then redone at end of build. They did not cap or cut. This caused a leak at neighbors junction and loss of 3 of 5 zones.
Steel weirdness
Steel, still some confusion about steel and pool size. No real help or clarification from PB. After some discussion, they dig.
Plumbing
Plumbers used the wrong non flexible pvc in spa, I told PB about the spa outlets pointing at odd angles. PB tells me it is flex pvc so no worries. I tell PB that it is not flex pvc. PB send guy back out that night. Guy comes out and cuts out the non flex, adds flex pvc using the same collars. He dug out with a knife the bits left in the old collars and re used them.
Plumbing 2
There is an obvious munson / error with the plumbing, weird angle of one pipe at the equipment pad indicating plumber had routed it wrong. The pipe is not vertical.
Coping 1
PINK flagstone - we picked what we were told was "Buckskin" it is not pink. It was picked after much thought so it would match the stacked rock. When the coping was delivered we told guys that delivered it NO ROJO it is like 6:30 at night, dinner time they begin to cut the stone!
Spa Tiled and more Pink coping
The next morning I called EDIT because I happened to notice they were tiling the spa wrong and they had continue to cut the pink coping! I told EDIT the sales person that flagstone was pink, EDIT the sales person talks on phone to foreman EDIT who just happened to walk up. I wrongly assumed they discussed both the spa and the coping. Tile guy has to remove tile and replace with stacked rock.
We were told that new stone would be brought out, but it was not.
Coping 2
Even if the coping was the right color, the pool is a geometric pool. The cut lines of the flagstone and the joints do not look professional. There are gaps at a joint and the same two pieces touch at the other end. The grout line will be a V shape. Not very geometric.
Tile 2
Stacked rock at corners of spa is mitered poorly.
Tile 3
Tile inside spa is not cut even. It is not straight at the bottom of the tile under dam wall spill inside the spa.
Equipment Pad
The equipment pad is too small, the filter canister, main pump and auxiliary pump do not fit, pump hangs over, not even bolted down.
Over flow
The overflow outlet is crooked, it is not set straight in the tile. I won't be sticking my head in the skimmer, however it should be set at a horizontal with the skimmer box.
Drainage!!
Brick -- how to set it on spa
Clean up?
Decking
Stamped Concrete
grading
fence
Irrigation
cleanup
startup
