I had a pool put in last sping to battle the wicked Tennessee heat {never experienced a summer in the south before} and it was great...I was deployed to Afghanistan however and the pool sat uncovered all fall and winter, so when I returned home recent;y, the water was black...
I started the pump, added "shock" to it, and got most of the leaves out....The water is now green, but not getting any better...I'm so glad I found this forum!!! I've been doing some extensive reading and I'm ready to tackle the algae
I'm headed out tomorrow morning to purchase bleach, Muriatic Acid, and CYA.
The only problem is, I don't know where to start...I know I have to lower my ph from 8.8 to 7.2, and raise my CYA from 0 to 30, but I'm not sure which one to do first...Also, should I add liquid CYA or powdered CYA? Can I add all 3 chemical at once, or do i have to add each seperately? how long do i have to wait in between adding? This seems to be an awesome site, and I can't wait to hear what all you pool guru's have to say...summer's around the corner and I want to swim soon!!!
Here's my water numbers if that helps ya guys, also included is what the calculator recommends...It's an 18x33 Oval
PH 8.8 add 39oz 31% muriatic acid to lower to 7.2
TA 79 OK
FC 0 add 3 gallons 6% bleach to raise FC to shock level 12ppm, add more every hour
CH 200 OK
CYA 0 add 1 gallon to raise to 30ppm
Please give me any input you feel necessary as this is all somewhat new to me...
Thanks
TA 79 OK
CH 200 OK
Thanks
