I have just had a Suntouch + Intelliflo pump installed today.
I am finding the set up and manual a little confusing.
It looks like the guy who set it up set up two schedules Low (for the filter pump) and Aux 2 for the cleaner booster pump. He also set up 3 pump speeds Low (Solar not running), High (Solar running) and it looks like the Aux two is set to an (slightly) higher seed than high.
Does all this make sense? He tells me although the Low is the only schedule set (apart from Aux 2) - if the solar runs (it is set to run on auto) the pump will switch to the high speed.
The manual doesn't even mention schedules for Low or High - it mentions schedules for the Filter Pump - but I don't see this option in the menu.
