I'm going to be installing my new liquidator this weekend and had a question on where to put the output line. I know it needs to go before the pump, but should it go before or after the automatic actuator that converts the flow between pool and spa mode? If I put it before the actuator, and the pool is in spa mode, no chlorine will be drawn from the Liquidator. My concern is whether the "In" line from after the filter will continue to push water into the Liquidator without anything being drawn out and possibly overflowing the Liquidator.
Also, I read Bama Rambler's post that he was having issues with the skimmer basket getting filled up and creating too much pressure to where the Liquidator drained in one day. I've got two skimmer lines and one line for the main drain. If I'm supposed to put it before the actuator, I'm assuming I should put it on the main drain line to prevent this from happening?
Last question, my Liquidator will be in morning sun, and I'm thinking I need to either paint or insulate it. If anyone has any pictures of how they have solved this problem I'd love to see them.
Thanks for all your help!
