The black dot should be completely gone, with no sign that it was ever there even after you stare at if for several seconds.
You can buy calibrated CYA test solution with a 50 ppm CYA level so you can practice the test with your current test kit. I'm not sure who sells it in Europe, but it is fairly easy to get here if you look for it.
