- Mar 31, 2011
- 6
good evening,
ok first off i have a indoor pool with aprox 60750 gal, with a salt level of 2500-2800 (depending if you look at a test strip or the digital readout on the board) for the last few weeks i have been fighting my chlorine levels unable to keep them between 2-3ppm. they were way too high (5+) so i turned off the SWG for about a week and they finaly came back down so last week i turned back on and also added enought chlorine to get my level to 2ppm. and have maintained that for about a week running the SWG at 40% no keep in mind i have two SWG Aqua rite systems on my pool because of the size. then 2 days ago someone else added a 40 lb bag of salt because he said the dip test showed 2300 ppm for salt. well the next morning the chlorine level spiked to 5 ppm. so i turned the SWG off and began adding Chlorine Neturlizer (SP?) to get rid of the high chlorine and that worked. SO..... I now have the SWG on but at 5 % and have not been able to get the FC level above .5 even after i bumped them to 30% any ideas?
FC .5
TC .5
ALK 120
PH 7.6
FC .5
TC .5
ALK 120
PH 7.6
