I have a pool with an elevated, attached spa that over-flows into the pool during normal operation. When the system is off at night the water level, which has normally stayed just below the out-flow lip has been dropping to the water level of the pool. The water level in the pool has not been dropping, so I am assuming there is no lose of water outside the system. I replaced the back-flow check valve for the spa but that did not correct the problem. Turning off the skimmer system and/or the valet cleaning system has had no impact on the water level drop. Could the new check valve be defected or should I look elsewhere for the solution...Thanks for your thoughts...
