I've got a quick question about an Intermatic T-103. Currently, my pool pump and spa pump are hooked up to this timer. Both the pumps are running on 240 volts, and only one leg of the 240v for each pump runs through the timer. Is this correct? The T103 is a DPST switch, so one leg to each pump is switched by the timer, and the other is constantly hot. I've had the house/pool for a year with no problems with this setup, just wondering if this is the right way to do this
