Results 1 to 13 of 13
Thread: Solar panel floating swcg?
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    One of my friends at work said he saw a swg at the pool store the other day that is basically a solar powered floater.
    Has anyone seen or used one of these? It could be pretty cool for a smaller pool, especially if someone didn't want to plumb in a swg. I just wonder how effective they are.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Jul 2007
    Brisbane, Australia
    874
    never heard about one, but would be interesting to see it. it would have to be a big solar panel to power the cell
    Arizona
    925
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    SeanB's Avatar
    Mar 2007
    2,622
    Yep, that's what he said he saw. Anyone ever use one or know of someone who has?
    TFP Founder
    Jun 2007
    Charleston, SC
    151
    From thier website:
    Research has proven that SolarChlor can chlorinate 1 gallon in 1 sec to 1 ppm. Results were obtained without concentrated salt in the bottom cap assembly.
    Excuse me if my math is totally screwed up....
    So bringing a 10000 gallon pool up 1ppm would take a little less than 3 hours. So if we estimate an average of 5.5-6 hours of sun a day, it would be equivalent to adding about 2ppm worth of bleach a day in a 10000 gallon pool.
    Doesnt sound totally unreasonable, especially for a < 10000 gallon pool.
    My only initial concern was that they say to shock once a week, which seemed odd unless you were expecting less than required chlorine production.
    18' Round ABG (8000 gallon)
    Hayward X-Stream Cartridge Filter
    1.5hp Hayward PowerFlo Matrix Pump
    80 sq. ft. solar panels
    Goldline automated solar controller
    Jul 2007
    Alamo, CA
    187
    From their site, I apparently need an algaecide with my SWG. That's news to me.
    I don't see any reason something like this wouldn't work, but I question its actual capacity. Somehow, I don't see it able to move enough electricity with that solar panel, since my generator runs around 150 watts to supply up to a 40,000 gallon pool. If this product claims it can do up to 15,000 gallons and mine can do 40,000, it seems reasonable to expect this solar system would require 15/40 of 150 watts or more than 50 watts. I don't know of any solar cells that size capable of producing 50 watts of electricity, especially since it needs to be around 50 watts of power going to the plates, not just the power supply.
    blubluenoiseise
    My pool: 14,750 gallons in-ground plaster
    FAFCO Solar panels (seven 4' x 12') with a Goldline automatic controller
    1/2 HP WhisperFlo filter pump, Kreepy Krauly cleaner, Cartridge Filter
    Aquarite SWG, Satisfied user of the TF-100 Test Kit
    Arizona
    925
    I think the thing that blasts out at me is "minerals". I'm not so sure I want to introduce that based on what I've read of the frog and those other mineral pak things.
    Buggs
    If this floating device uses salt depleting process to produce hypochlorite, than it is way too small.
    20k gallon pool would need aprox 300gr of 100% pure disinfector per day (in summer).
    Say, semi bipolar cell assembly (very efficient cell design by the way) made by our company uses about 130Watts per hour to produce 30 gram of disenfector. If you have 5 hours of bright sun per day it will take about 260wats/hour to produce required 300 grams per day.
    So, you would need about 300watt solar panel to chlorinate your pool in 5 hours. Here is the link how 175watt solar panel look like : http://www.solaronline.com.au/cgi/index ... 1107358703
    keep in mind you would need about two of those and no clouds.
    Hoverer if this device uses coper / silver dissolvable electrodes, than it may need less energy, but swimming pool still going to need some chlorine added however the total free chlorine residual can be kept lower due to presence of copper and silver ions.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Quote Originally Posted by Valera Orlingis
    are you advocating copper and silver ions?
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    tagprod, I know this technology work and also know to what extend, but I like to discuss rather advocate Presence of the ions of cu and ag in the pool water have some positive effect on disinfection, but cannot be stand alone disinfection solution as chlorination. Same as ultrasonic water treatment, UV water treatment, Ozone and few others...
    We specialize in salt water chlorination, but done R&D in others as well
    Copper/silver system do "work" but they have associated problems that make them undesierable. In order to have useful/effective amounts of copper/silver in the pool you need to be at levels that can cause staining. To prevent the staining you need to keep very tight control over the PH, which is impratical for most people.
    There is no way the solar cell on the floating SWG is going to produce enough electricity to produce as much chlorine as I would recommend using, though it is remotely possible that it could produce enough chlorine to get to the levels that copper/silver systems recommend.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    3000-6000 ppm salt? My SWG only requires 2000-3000 AND cost less than theirs so how is it half price than others? I have seen several inline SWG for less or the same price as theirs.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    I would guess that when you compare the same quality chlorination system and CU/AG system, SWG will cost more due to higher cost of anode material used. CU/AG electrodes are cheaper and powesupply module for them can be less sophisticated due to simplicity of driving sacrificial anode.
    But, SWG cell will last normally 5+ years and CU/AG about 6 months. So even if CU/AG is cheaper to purchase in first place at may cost you more on the long run depending on cost of replacement electrodes and a nesesaty to still add chlorine.
