We're new green pool owners as of December 2009. We've bought tons of stuff from the pool stores, but still have yet to get the pool clean enough to swim in. The pool is mostly blue, but still cloudy (we're still finding algae when we brush). The water test kit (K-2006) is in the mail and should arrive this weekend. The pool water was tested at the store on 8/14/10 with the following results:
FC - 7.4
CC - not available
pH - 6.6
TA - 80
Hardness - 310
CYA - 100
Borates - not using
We've been using the pucks in the floater, but we took those out today. We've also been shocking with the powder cal hypo, but we're switching to bleach effective immediately.
We live in Central Florida and the pool gets sunshine all day--does this qualify as "extreme sunshine" to justify a higher CYA? If so, the plan is to drain 30% of the water to reduce the CYA to 70 (based on the Pool Calculator). Then we would raise the pH and shock according to the directions in the Pool School. Should we wait until the pool test kit arrives before we drain or go ahead and start the process based on the pool store's numbers?
This forum is great! We've already learned a great deal from all your expertise!
Sara and Gary
FC - 7.4
CC - not available
pH - 6.6
TA - 80
Hardness - 310
CYA - 100
Borates - not using
Sara and Gary
