kal2002 said:
You guys are so very helpful and I am learning a lot today. Thank you so much.
Yes, MA is strong smelling. This is my first time handling it. Next time I will hold my breath when I do the measuring.
So you are saying that each time I want to lower TA, I should lower the pH to 7.0 or 7.2. After TA drops, increase pH back to the normal range. And I can keep doing this process until I get to the desired TA level?
Another question: can I increase ph by adding borax instead or will this be too many chemicals in one day?
VERY IMPORTANT -- you will allow the pH to rise with aeration or just letting it rise over time, NOT CHEMICALLY.
You can to it fast, moving TA by maybe 10 points at once with dropping to 7.0 and aerating. Or you can do it slow, moving TA by maybe 3 points once or twice a week with normal MA additions that you do whenever the pH gets to 7.8 to bring it down to 7.2 or so.
It just depends on whether you want to mess with it a lot now or a little along the way. I've done it both ways and, eh, slow is fine for me now. If the CSI number on the Pool Calculator says you are in a bad range and correcting TA will fix that, then I'd work it faster. If it is just a matter of being out of the suggested range and having the pH rising, I'd work on it slowly.
Just know that TA is one of the last things you bother to fix.
And I suggest that you keep records in a book of these tests and what you have added. For example the trichlor tabs you added will have some calculated effect on CYA, so make a note that this should per Pool Calculator, add X ppm CYA to pool. It will show up eventually. If you use 5 or 10 or 20 tabs it will accumulate and eventually show on test, this way you won't be surprised.
Also, holding your breath is sort of doable, better to be up wind. Most important is eye protection. You can wipe it off your skin, but you can't get it out of your eye fast enough.
