It went good, the generator works great! I love it for the price. I'll attach a link to the rar (like a ZIP file) of the pics. its aprrox. 50meg I needed more epoxy soo it has a small leak it one coupler. I didn't want to use the cheap flex hose included. I upgraded the return to 2" from the Multiport valve to the SWG then down to a coupling in the ground. Being as I was adding several 90's bumoing the size from 1 1/2" toi 2" slows the valocity and makes the addition on the few 90's not as bad to the system flow as compared to if I stuck with 1 1/2".
Next I'm going to add a simple 9v battery backup so that the SWG dosen't reset to off/standby/lost programing everytime the power goes out for .5 seconds, yes .5seconds, thats all it takes and she's off again.
So heres what I did
1. cut thin flex tube off then cut out of collar
2. sand the inside with 150 grit sandpaper so epoxy will adhere better
3. cut 1 1/2" pipe to barb adapter form Lowe's down in length
4. sand barb surface
5. wash dust off parts and dry
6. mixup epoxy, very messy stuff.
7. do your best to fill the gap with epoxy.
I used a .2oz cheap tube from Harbor Freight on one end and it wasn't enough. I ended up with a pinhole leak, now it drips constantly. use AT LEAST 1 oz. on EACH end. I tryef Marine epoxy putty around my leaking adapter and it only helped but didn't seal it.
I would love someone elses advice as to making custom plumbing adapters and using expoxy, it was a mess! I'm dissapointed one end leaks so I have a permenently soaked cement pool equip. pad.
On the upside SWG makes great Chlorine. got my salt from Sam's Club. 5.88 for 40lbs, Morton brand in the white bag, labeled for pools, same as in pool stores but cheaper!
