Just bought a house with pool and attempting to open it for the 1st time (although the pool is quite old).
Here are the details of my pool:
1.It is rectangular 25 ft x 15 ft.Depth is abput 5 ft.
2.The color of water is green.
Here are the test results done today by a pool store:
FC:0.09ppm
TTL Chlorine:0.09ppm
Comb Chl:0.0 ppm
pH:7.80
Hardness:90.0ppm
Alkalinity (w/stabilizer correction) :67 ppm
Cyanuric acid:10ppm
Copper:0.04ppm
Iron"0.00ppm
1.I talked to 3 pool stores and they told me different amounts of chlorine I should put.This one said 3 lts, one said 10 Lts and one said 20 Lts.So I m confused :!:
2.He has asked me to put foll besides chlorine:
a)Aqua Trol -1kg
b)Aqua Cal - 2 kg
c)Aqua Stab-450 gm
d)Algacide
So far, I have just added Aqua Trol.Do I really need Trol,Cal and Algaecide?
2.The vinyl liner of one wall was coming OFF a bit before I filled water.Once I filled the pool it sunk in and now due to weight its immpossible to pull it back up.And and don't want to drain the water as its lots of to waste.I have put a patch of liner for now and will try to fix the orignal liner at the time of closing the pool.Is it allright to do so?
Here is the picture:
http://picasaweb.google.ca/100642790066 ... 5524095650
FC:0.09ppm
Comb Chl:0.0 ppm
pH:7.80
Hardness:90.0ppm
Cyanuric acid:10ppm
Copper:0.04ppm
Iron"0.00ppm
a)Aqua Trol -1kg
b)Aqua Cal - 2 kg
c)Aqua Stab-450 gm
d)Algacide
