First I have a 27' roung ABP pool that is 54" high... Approx 18500 gallons. I started with:
PH 7.3
Baquacil 29ppm
TA 93
Calcium 180
Baqua Oxidizer 3
Dissolved Solids 0
Sat Index -.35
The Pool temp is nearly 90.
I Put 4.5 gallons of 6% bleach in and it immediately started turning green! I know that is good. I unfortunately only have the Walmart test kit so I can only test to 5ppm for Bleach. About every thirty minutes I have been testing and adding another 3-4.5gallons of bleach each time. I am concerned that this is too much? How much bleach can I expect to use through the conversion? I have the next couple of days to babysit this and do it hourly as suggested.... Can I expect to have this done in 3-4 days?
Thanks...
I am taking pics and documenting want I am doing so when it is done I will post everything!
PH 7.3
Baquacil 29ppm
TA 93
Calcium 180
Baqua Oxidizer 3
Dissolved Solids 0
Sat Index -.35
Thanks...
