It seems that the weak exchange areas of our pool are subject to a little bit of algae even if I don't go below the target FC level. Is it ok to have a little extra FC, say 3-4ppm, in the pool just to be safe, along with brushing the affected areas. I'm kind of assuming the answer is yes, seeing that it is safe to swim in the shock level of FC for a given CYA. Thanks.
