Hello, i really need help with this.
Last Thursday the land lord bught a hayward pool vac which goes all around the pool cleaning by itself and told me to vacuum the pool with that.
I read the manual and watched the dvd intallation guide and i understood everything. The only problem i have is that you need to plug a flow gauge in order to test for the recommended suction. If the suction is too high you need to slightly open the main drai untill it falls to the recommended suction and if its too low you need to plug a regulator valve into the skimmer cone which connects to the hoses.
After that i turned the regulator valve into max the flow gauge still shows that the succion is too low. I also checked that the main drain is compleately shut off so only the skimmers are working.
Does anyone has any idea what should i do? please let me know if you know how to fix this, thank you
