Hello All,
Relatively new to owning a pool, but we recently opened up our pool and our Pro Logic PL P4 computer is not getting the correct salt levels or temperature. This is only the second season using it. It reads 2400 PPM but we had it test and it was at 3350 PPM. Problem is that since it thinks the salt levels are low, the turbo cell will not turn on. Not to mention the water temp it reads is way above what it really is and the heater will not turn on either. Is there a way to HARD Reset the system? I tried killing the power to it but it resumed where it left off. Any advice would be greatly appreciated. Thank you!
Here are my results:
Alk: 40
pH: 7.1
Cyanruic Acid: 20
Hardness: 90
Total Chlorine: .5
Put in 17lbs of alkalinity today.
Alk: 40
pH: 7.1
Cyanruic Acid: 20
Hardness: 90
Total Chlorine: .5
