Hi, Lori,
Good pic...that helps
The murkiness will probably slowly go away simply by filtering as you suggest.
It would probably be a good idea to elevate your FC level up around 6-8ppm as long as the cloudiness is present. That way, if you still have some living organics contributing to the cloudiness, the additional chlorine should help the clearing process go a little faster.
I misspoke about the baking soda....I'm sorry. That said, I would leave both TA and pH right where they are.
