Most articles I've read here, and my own personal experience, indicate that the solar covers reduce chlorine consumption by a little bit. I believe there are a lot of different factors that influence this and to what degree. Your mileage may vary.
As always stressed in the forum, it's important to have a good test kit, and test frequently so you understand the impacts and how your pool behaves.
From your post, it kind of sounds like you are having issues with chlorine loss, which is more likely due to organics consuming the algae or low CYA. A solar cover isn't going to make any different with these.
Good luck!
Steve
