Results 1 to 15 of 15
Thread: Backyard Patio
    Mar 2010
    Spring, TX
    1,082
    Backyard Patio
    Right now we have a wood patio, but it just does not go. We are going to pull it up and we want to pour down cement. Has anyone ever done this and any tips or tricks that you may recommend. We will be doing this over dirt. I told my wife we should do bricks, but she is concerned about stuff growing up in between. I told her we could use some caulk in between the bricks to prevent this. The bricks would be a lot easier to do, except around the other areas to where the concrete will match up to the existing patios.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    jmack1159's Avatar
    Apr 2010
    Arkansas
    45
    Re: Backyard Patio
    I was researching this the other day and found an article on how to pour a concrete patio. Follow the link below. They make it look really easy.
    http://www.diynetwork.com/how-to/how-to ... index.html
    24' Above Ground installed March, 2010
    22 Sand Filter With Zeolite
    1.5 HP Motor Pump
    Successfully using the BBB Method!
    pool-school
    Dec 2009
    Central Massachusetts
    2,690
    Re: Backyard Patio
    Have you ever poured concrete before? It's not as simple as just pouring out over dirt. You need to form it up, put in sand base, shoot the grades for level, then finish it properly.
    It's not as easy as it looks.
    For a paver patio, you dont caulk the joints, you use polymeric sand. That keeps stuff from growing in the cracks. But, laying pavers takes some skill as well. Same kind of grade needs to be shot, the proper underlayment needs to be put in, compaction, etc.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mar 2010
    Spring, TX
    1,082
    Re: Backyard Patio
    Quote Originally Posted by bk406
    My wife has done it before. She used to go on church retreats and would do this type of thing. From reading you basically need to have a base area to pour it in. She used to use some type of chicken wire. Also you are supposed to pour it a little higher so when it settles.
    Dec 2009
    2,690
    Re: Backyard Patio
    Quote Originally Posted by mynewpool
    No. What area of the country are you in? Depending on where you are, you could get this professionally done for 3-4 bucks a sq ft.
    Mar 2010
    Spring, TX
    1,082
    Re: Backyard Patio
    Texas. I read on the internet you do it a little higher so when water or something is cleaned off it is level. I may not be using the exact correct terms, but something of that nature.
    Mar 2010
    Spring, TX
    1,082
    Re: Backyard Patio
    Quote Originally Posted by jmack1159
    This is what I was looking for. Thanks for the helpful info.
    Dec 2009
    2,690
    Re: Backyard Patio
    My advice is to have this professionally done. To be honest, the questions you are asking leads me to believe that a DYI job would be a disaster. You really want something that will look good around your pool. I'd hate to see a bunch of hard work and effort go into something you will not like. Sorry to be so blunt, but IMO, there are some great things a person can DYI. But, if you have little to no experience, concrete isnt one of them. Especially when you could get it done by a pro pretty cheap.
    If your bound and determined to DYI, read all you can. And again,no, you dont pour it higher than you need. Not sure what you read or the context, but that is wrong.
    Re: Backyard Patio
    And slope is important, you do not want rain running into the pool. Nor do you want rain running into your house.
    Mar 2010
    Spring, TX
    1,082
    Re: Backyard Patio
    Have you built a patio before?
    This is what I saw
    Use a wheelbarrow to transfer the mixed concrete from the mixer to the project site. Then, using a shovel, distribute the concrete evenly and ensure you get plenty into the corners and against the forms. Build it up slightly above the forms (about ½") and then use your shovel to "stab" at the concrete vigorously to vibrate the concrete and help it settle and compact.
    The form is referring to the area around that you have layed down prior to pouring the concrete?
    Dec 2009
    2,690
    Re: Backyard Patio
    I understand what they are saying about adding a 1/2 inch above the forms. But, it's not saying exactly what you think it's saying.
    Yes, i've poured patios and house slabs. And..i've put in paver walkways, patios, circle packs, and one 1000 sq ft paver pool deck.
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Backyard Patio
    We just had a 16 x 16 patio extension poured when we had our pool built. I did the grade and had the pro's form, pour & finish it (broom finish). The grading was easy as the soil where I live is rock, sand and clay. We also had them pour two free form pads leading to the pool area about 27 sqft. We bounced the pavers idea around quite a bit as well but it would have been more cost for the extra grading and materials. We are really happy with the way it turned out. It has really improved our backyard. They make thin pavers to go over concrete if down the road you change your mind. We paid $927.00 for the patio extension and the free form pads. I only mention that because I know for most of us cost is an unkown and a big factor. Here are some pics of the project.
    Formed and ready to pour
    The crew
    Finished product
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Dec 2009
    2,690
    Re: Backyard Patio
    Nice job. I like the free form design.
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Backyard Patio
    I'm a DIY'er to the core. I did my pool barrier, landscape and everything else I can do to save myself some money. This was not a project I wanted to tackle myself. There is way to much visual impact to gamble and way to much cost and labor to have to redo it. Keep in mind there were at least 8 guys doing this job plus a cement truck. You can get good concrete pro's on Craigslist all day long.
    2' Powerfall
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Backyard Patio
    Thanks
    2' Powerfall
