Getting ready to order pool to setup next year. We want a SWG and the place we are buying from sells the AquaTrol. Model is AQ-TROL-RJ and says it's sized for 18,000 gallons.
The picture doesn't have a timer dial on it like some others I see. Would I need to purchase and install a stand alone timer to run the pump and SWG at the same time? Should the pump run different times than just when the SAG is on? Slightly confused on how this would be set up.
Thanks.
Thanks.
