Hi:
I'm new to this forum. Seems like there is a lot of good info here! I just replaced my Spa jets pump(Hayward SP4010NS) and everything worked fine except that when I turn off the pump water comes back from both return and suction sides overflowing the basket. I had to close the manual shut off valve on both sides to avoid overflowing. The pump is directly piped to the Spa jets(doesn't go through the pool\Spa filter). Any advice will be appreciated......
Monty
Monty
