Hi,
I need a help here.
I got this pool with a house we bought in June 2009. I started to read TroublefreePool almost immediately and learned a lot. Thank you very much to you all. My pool is a real pleasure and I have not had too many problems with it.
Well, almost.
The Cell light on my Intellichlor IC40 started flashing. I found some scale in the cell and did an acid cleaning, it helped for 3 weeks, and then it started flashing again. The whole summer and fall I had to clean it every 2-3 weeks, and the scale was not even too bad.
Our water is very hard, CH was about 800, and TA was 250, I thought that the scale problem was caused by those high levels and managed to lower TA to 80. It did not help at all. Then winter came, the water temperature went to 50s, and I turned the cell down.
Two weeks ago I decided to prepare the pool for the season and replaced the water.
Now CH is 250, TA is 180, PH is 7.8, so everything looks not bad, but I cannot make the cell work at all. There is no scale, it is absolutely clean, but the “Cell†light is flashing. When I turn it on it is doing the usual start-up test, then “High Salt†light flashes for about a minute, then the “Cell†light starts flashing. I tested the salt level using various tests and it is about 3500, which is perfect.
I am lost now and need help.
Thanks.
I need a help here.
Well, almost.
Thanks.
