We opened our pool about 2 weeks ago, hooked up the pump, put the hoses back on and connected the light, etc. When we took the cover off, the remaining water was crystal clear and still is. We filled the pool with water so the water level was to skimmer where it should have been and have been running the filter everyday. I have not tested the water yet, because no one has been swimming because it is COLD>> but since the water looks good, do you still need to shock the water if it is not green?
Thanks
Christine
Thanks
Christine
