I am changing all the plumbing in my pool. The equipment details are below, but basically all accept either 2" or 2-1/2" size pipes. The underground line runs will be 2". My question is - for above ground plumbing, should I use 2" with sweep elbows or 2-1/2" with 90 degree elbows? (I do not consider 2 1/2" with sweep because I can't find the parts and if I would, it takes too much space and is probably an overkill. )
