2 Speed pump trips breaker on high speed
May 15, 2016
34
Central Valley/ CA
Hello all,
I have a jandy 2.0 SHPF 2-speed pump that started tripping the breaker on high speed. It ran for several hours yesterday on low speed but instantly shut off when switched to high. I did notice the motor was fairly hot to touch. Today, it will run on low speed but takes an abnormally long time to prime. When I switched from low to high, it ran for a couple seconds and shut off. It also tripped the breaker, which now has gone bad. The pump is run by an Intermatic timer.
Any ideas?
