Hello all,
I've been reading up on opening my pool (for the first time; previous 5 years I've used a service). I'm mostly ready thanks in large part to reading the info here. I have a couple of quick questions, though:
1) When removing the winterizing plugs, they should be in the returns and skimmer. Anywhere else I might be overlooking?
2) After starting the pump, should I vacuum/scrub/run the pump a bit before adjusting chems? I'd think I'd want to get the water flowing and mixing, but I also don't want to leave the pool exposed too long with poorly maintained water.
3) With the caveat that cases can totally vary, the general sequence of chems is: Alk, pH, CYA, Cl? In general, I should adjust each one before moving on the next, correct?
4) To save myself time on opening day, is there any reason I shouldn't put pump/heater drain plugs in beforehand? I know it's a minor step, but I'll have my hands full doing this for the first time, so whatever I can check-off the list will be one less thing I have to worry about on the big day. Any other pre-actions recommended?
Thanks as always!
Thanks as always!
