Re: Overnight Free Chlorine Loss
I totally understand and we will help you do this.
To determine your gallon level, you can use the feature in the pool calculator. You have to know your gallon level to truly be able to accurately dose your pool with the chemicals.
Tonight, after it is dark, check your FC. Then in the morning, before the sun is up, check the FC again. That will give us your loss. Be sure and run the pump continually during this process.
Post your numbers back here in the morning and we will go from there.
Also consider creating a signature line under your profile that includes your: pool type, pump size, filter type, number of gallons, and any other specifics about the pool structure. That way, when you post that information always appears and we know what you are working with.
This seems hard because you are a business owner and you work a full schedule. I think that you are letting this aggravate you more than it needs to though. Aside from doing some testing and adding some chemicals to maintain things, you can sort of let things handle themselves. Test when you need to and be accurate. You don't have to stand out there with the pool the whole time or anything. Just keep checking up on it periodically, check your overnight losses, and post back here when things develop or questions arise.
