I bought one of these little pumps a month ago and had to defective exchange it a few days ago. The following is a test of the new one. I don't like the pumps priming issues but if you get it going it moves some water for 40 bucks. Currently on sale for 30 bucks
Link>> http://www.harborfreight.com/1-inch-cle ... -1479.html
Factory Specs from site:
â– 115 foot maximum total lift
â– Maximum capacity: 650 GPH SOme dispute here, The name plate says 330 GPH my test reveiled 400 GPH
â– Compact design with mountable feet
â– 1/2 HP motor
â– Ideal for permanent installations
â– Cast iron construction
110 volt motor
3200 RPM
Weight: 14-1/4 lbs.
Link to factory manual (i tried to upload but it's 750K size prevented me>> http://manuals.harborfreight.com/manual ... 9/1479.pdf
Specs on the housing:
Brand: Pacific Hydrostar
120 v~
60 hz.
1/2 HP
2850 RPM
Max Head Lift (Output) = 115 ft.
Max Suction Lift (intake) = 10 ft.
Capacity: 330 GPH
Item 01479
I used a Kill A Watt EZ for testing Link>> http://www.homedepot.com/Electrical/h_d ... ogId=10053
Their cheap there now! 24.99 lowered from 29.99, some placed charge 39.99-44.99 for the same thing. And YES this is th emore expensive EZ model Look at the dark bezel around the display, thats the EZ.
The difference is you can enter your Kw/hr rate into it and it will calculate cost and show it as a live updating number. SHows cost per day, week, month, year and Total cost since plugged in, using the build in time since pluged in counter. And there are several other measurments.
Test results
Testing voltage: 118
Watts: 395
Volt Amps: 591
Amps: 5.0
Power Factor: .66 <<thats ugly!
operating cost per hr at 10 cents(check your local rates) per Kwh: 3.9 -or- 93.6 cents a day (24 hrs continuous)
Inlet hose: 5 ft. 5/8" garden hose - 6inches lift from pool
Outlet hose: 25ft 5/8" garden hose - 12inch lift into 5 gallon testing bucket
Total lift 1 1/2 ft.
FLOW: .111 gal/sec. or 6.66 gal/min. or 400 GPH
â– 1/2 HP motor
110 volt motor
3200 RPM
Weight: 14-1/4 lbs.
120 v~
60 hz.
1/2 HP
2850 RPM
Capacity: 330 GPH
Item 01479
Test results
Watts: 395
Volt Amps: 591
Amps: 5.0
