Can someone point me in the right direction to find info on troubleshooting this. The manuals and Goldline/Hayward websites don't give any detail as to what the cause or solution to this error could be. Thanks in advance!!
mirage said:Thanks Steve, This is priceless! I owe you a beer! I just completed this repair.
Thank you, I have managed to make the solder trick work three times in 10 years now, it took three attempts to make it work this time. make sure you heat up the post sticking through the back of the board on the opposite side and apply the solder to the other so it isn't "cold" bit I will keep this trick in mind for the next failure.Just stumbled across this thread - funny that I had the same problem on our old pool but didn't know about the forum at that time - I noticed that if I pushed on the relay it would click and all was well - pulled out the board and saw the burned up solder joint on the backside.
I too was unable to solder the joint back to the board and get good contact, just too much damage, howoever if you look at the layout of the board you will see that "post" is connected to a couple other posts via the trace on the board. I soldered a jumper wire from the affected post to the larger post above it effectively bypassing the trace on the board. I wish I had taken pictures, but if you look at the board you will see a large power wire feeding into the larger post, that is the one you want to tap into and jumper from it to the burned up one.
I attached the photo from the website mentioned above with where I placed the jumper wire from my best recollection. If you have a multimeter you should have continuity between those two points in the picture. If you do have continuity and still have problems then it is somewhere else - possibly the relay itself. Ours worked for the next couple years until we moved.
[attachment=0:3qfo8mea]solder.jpg[/attachment:3qfo8mea]
Steve
