Results 1 to 10 of 10
Thread: Goldline Controls, Pro Logic controller question
    Not sure if this the right location for this or not, but hoepfully someone can help me. I have a GoldLine Controls Pro-Logic control system for my pool/spa. About 6 months ago, the valve acuator for the pool/spa suction quit activating when the unit was placed in Spa mode. Essentially this placed the unit in "Spa Spillover" mode. I thought the actuator was defective and went and pruchased a new one, however the new one did not function either. So I started experimenting and found that actuator would work prperly if I plugged it into the "return" spot instead of the "suction" spot.
    So I was able to determine that for whatever reason the suction actuator is not being activated by the control module. I am hoping that someone with some knowledge of the control systems can help me either A. figure out what is wring with the suction relay/control, or B. reprogram the unit to activate optional vave 3 when the pool is placed into Spa mode, so as that would solve the problem too.
    Any help would be greatly appreciated.
    Bryan
    18K Gallon In Ground Gunite Pool, Quartz/Plaster Finish, 8' Spa with Spillover, 1 Grotto/Waterfall, Hayward/Goldline PS8 controller, 1.5 HP Two Speed Pump, 1HP Booster Pump for Grotto/Waterfall, Cartridge Filter,400K BTU Nat Gas Heater, Ozonator,3 Multi-Color LED Lights (Spa, Grotto, Pool).
    Ozonator is not functioing, evaluating my options, either fix it or get a new one or drop it completely.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Goldline Controls, Pro Logic controller question
    Bryan, I HOPE I can help you
    I can make it happen when the unit is in front of me, but can't do it without pictures
    {SHUT UP ALL YOU WISEACRES!!! }
    If you get me a pic of the valves and the panel connections, I can probably help you this weekend, when we (hopefully) both have time to deal with this. (We may have to talk on the phone, I'll pm you my phone # when needed )
    Luv& Luk
    -Ted
    Thanks. I will get some pictures posted before the weekend, and we can figure out what we need to do as far as phone calls and such. Already I have learned this "controller" can do so much more than is apparent from the user interface, if only I could find a detailed programming manula...their installation guide was a bit confusing to me, but maybe if I printed it and read it instead of trying to read it on the screen. . .
    Okay. Here are the pictures I have of the equipment. Hopefully this al;l makes sense Alternatively I may just call a pool guy to come "fix" whatever is wrong with the system, as I am having problems with the ozonator as well, and that is either a byproduct of the other problems with the controller, or a blown transformer in the unit itself, or a burnt out light bulb. . . .
    This is the "return" valve where it switches from the pool returns to the spa jets.
    This is the "suction" valve where it switches between the pool drain/skimmer and the spa drains (there is a manual valve to the side where I could switch between full pool drain - to full suction side cleaner or anywhere in between but I replaced the suction side cleaner with a polaris 3900 recently).
    this is the control panel/brains of the whole operation
    here is a close-up of where the wiring for the valves attaches to the control panel (the return valve is connected to the one labeled "return" and the suction valve is now connected to the one labled "valve 3" because the one labeled "suction" is no longer functioning)
    Let me know if you need anything else. Thanks.
    At the bottom of the last picture, I see a cable with a red plug on the end that is not plugged into anything. What does that cable go to?
    That goes to the old valve actuator before I replaced it, once I discovered the actuator wasn't the problem, I left it because I eventually want to use that actuator (after a little replumbing) to automatically switch the booster pump between the water fall and the polaris.
    I'm pretty sure it all boils down to a programming issue. Once I figure out how to program the controller to activate valve 3 to "on" when the pool is in spa only and spa "spillover" mode, and "off" when the pool is in "pool" mode, my probem will essentially be sloved.
    After additional research it doesn't look like what I want to do is possible/feasible. I will have to have the unit serviced, I just hope the solution isn't to replace the unit. It appears that it is only the "suction" valve acuator control that is broken, but I am not sure that is something that can be repaired.
    Mar 2007
    4,160
    OK, hold on a minute.
    If all you want the 2 valves to do is turn at the same time every time, I can help you Simply slice the 2 cords together into one input
    It's the programming and 'group functioning' that I have to stand in front of the unit to successfully do All you want to do is include valve 3 in the pool/ spa changeover. Call Goldline and tell them that valve 3 is solar and you want the valve to automatically turn to use the propane heater when you go the spa mode (it's a lie, but they'll be able to tell you how to include valve 3 as a group function).
    You may want to try this before calling in the expensive guys
    Luv& Luk
    -Ted
    Thanks. I never thought of that. I did contact them with the original problem, and of course they told me to contact the expensive guys. . . .but if I re-phrase it as a solar question that should work. Thanks for the help/suggestions. I'll let you know how it turns out.
