mas985 said:And that is with a dirty filter, correct? That is really low for an uprated 1.5 HP pump. Can you describe your plumbing to me? Lengths and number of runs pool to pad, pipe size?
It is dirty.
With solar off:
Pump to first return jet (this is the one with the bubbles. This is also the one that practically turns into a hot tub when the solar is kicked on due to all of the air that's getting pushed out)....My guess is maybe 15'-18'. The next jet on that side another 10' and the next another 10'.
with solar off:
I'm going from memory, vertical maybe 10', horizontal maybe 35, vertical maybe 10, horizontal maybe 14, then into the panel, so that would be about 70'.
Here's a view from last summer. The first return just is just to the right of the chair.
Here's a view down the plumbing run.
Here's a view where it goes up and over the eave. Note, I hadn't finished painting yet, so the elbow stands out to differentiate from the downspout.
