Thread: Any way DE entering pool could be normal?
    In another thread several members helped me learn how to repair a leaking pump outlet fitting. I simply used pipe dope and the leak seems stopped. During the process i turned off the suction line valves and also turned the multiport to the winterize (in between) position.
    After the repair, I started everything back up and forgot to move the multiport back to filter. The waste hose started to fill quickly and within 5 seconds i killed the pump. Then i moved it to filter and resumed.
    Again, the leak was stopped but i noticed the water turned a bit milky. I let the pump run for about 30 minutes and then killed it. After killing the pump and letting things settle i could see a bit of "grey" colored debris on the bottom of the pool. I recognize it as DE that is wet.
    Keep in mind that it was a very small amount and i just swept it all towards the drains. Also i watched the returns carefully and saw nothing visably coming out. I wonder if i didn't somehow knock some DE powder off the grids and into the return line.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    South Central NJ
    3,192
    Re: Any way DE entering pool could be normal?
    Most likely cause was just that.
    Scott
    Normal is a wash cycle.
    Owner of - PoolGuyNJ LLC
    Quote Originally Posted by PoolGuyNJ
    Scott
    Thanks Scott!
    10,000 gallon
    NC KANSAS44
