- Aug 17, 2009
- 185
I was wondering if there is a way to program the intellitouch to switch the flow of solar heater water from the pool to the spa once the pool is heated to the desired temp.
My Mobiletouch allows me to set the desired temps on each and dictate how both the pool and spa are heated but I cannot seem to find a way to get it to transition as stated above. Is there a way to set a priority like solar heat the pool first then the spa?
Also- if there is a way can I set a spa solar speed for my VS pump and a spa "use" speed when I actually want to use the VS as a jet?
