patinsd said:PoolGuyNJ said:Pat,
In the picture with the 320, does the pipe closest to the wall feed or receive water from the 320?
Does the JVA in the same picture direct water to the pool or spa, depending on the mode? (Mode = Pool/Spa, Spa Fill/Drain) or is it feeding the solar?
Scott
I just add a pic from the top .
So ,in the picture closest to the wall is the pipe who water from the 320 .
The JVA direct water to the pool or spa just like you said ,I do have another valve for the solar .
Thanks Scott and happy Easter
I am glad you ask question ,thanks
What size and model pump do you have? Haward RS 1000 1hp
Are the panels 1.5 or 2" plumbing? 2"
Are there any other restrictions? From what I saw, everything appeared to be 2" above ground. 2" all over
How high are the panels? highest point is 28ft ,lowest 20ft
Are they all in parallel and on a single level? yes
When the company installed the solar system ,they check for the pressure and said it's OK and every thing worked fine until I switch chlorinator .
I am going to try tomorow what jasonlion asked me to do .
