Is it possible to hook-up an intex swg to my in-ground pool. we are low on funds and need to do something. If I plumbed it in to my existing system how would it know,wouldn't it still work?
Yes this can be done. The Intex unit doesn't care where the water comes from. The main, fairly large, disadvantage is that the Intex SWG is not UL listed, so it is a code violation in most places to use it in this way. Also, keep in mind that the Intex instructions say to make sure the SWG is turned off any time someone is in the pool.
The unit is marketed specifically for temporary(non-permanent) pools. IMHO don't think that there would be any point in UL listing, nor would it be a code violation if it were not permanently installed (ie, you don't hard wire it.) It is always a good legal point to recommend that ANY electrical device connected to a pool be de-energized when someone is in the pool. The lawyers at the other pool equipment suppliers are just lagging behind, or not as paranoid!
