I've recently moved into a house with a pool! The pool has an SWG but the owner says they didn't use it. I had the water tested and came up with the following:
FC - 5+
PH - 7.6
TA - 170
CH - 630
CYA - 80
TDS - 2500+
Salt - 2500
I want to use the SWG so I know I need to raise the salt to about 3200. I'm adding acid to try and get the TA down to a reasonable level. Should I be concerned about the high CH? I think the owner just dumped a boatload of chlorine in the pool before I moved in. I've been there a month and haven't added any yet.
Steve
FC - 5+
PH - 7.6
TA - 170
CH - 630
CYA - 80
TDS - 2500+
Salt - 2500
Steve
