Looks like I have the exact same problem as you. {Split off of this topic. JasonLion}
No error codes, and no LEDs lit except Power LED, with an occasional 'Cell Reversing' lit.
Don't know if you recall, but the LCD display shows 'wait' on the lower right and the manual doesn't say exactly what that means or what its doing. :?:
There is no FC and so I have been adding jugs of clorox for now, as the pool is turning green.
You mentioned replacing pretty much everything, including plumbing?!
You said further error codes, how did you finally get error codes to appear?
Do I need to just buy a sensor? Or I need a whole new cell? I hope the control box and backboard is fine...
Is it true that the Jandy warranty for the APURE1400 is 2 years? Mine is not yet 2 years old.
Thanks.
Thanks.
